Old 07-14-2011, 11:16 AM
jeff6645 jeff6645 is offline
Default Twin 250's on a SF 23'?
I have a older Yamaha 250 that the shaft is stuck in the crank and I mean really stuck... have taken it to 3 differnt shops and all have given up on it. I allowed one to cut the lower unit off to get to the shaft and still no luck removing it....
On to my question; The last shop I took it to has a set of twin Yamaha 250 4 strokes that they pulled off to do a repower and they have made me a great deal on both... they want to sell them as a pair. I think read somewere that the boat is only rated for 400hp total, is that true? Would it be to much weight? To much power? Unsafe? Would you do it??? Or buy both and sell one?
Jeff Pettit
Pettit & Pettit Enterprises
Mobile, Al.
1974 23' Yamaha 250 OB
Love My Classic Seacraft
Old 07-14-2011, 11:52 AM
Basspond Basspond is offline
Default Re: Twin 250's on a SF 23'?
Those F250s are over 600 lbs each, probably too much weight on the transom...
2001 23 Regulator 2006 F250 Yamaha
Old 07-14-2011, 12:59 PM
Won't work - its only a 23' boat for petes sake - you only need 1 250
Since the LU is off - pull the powerhead with the shaft, then they can get at the shaft with heat better
Old 07-14-2011, 07:59 PM
GodsReel GodsReel is offline
not fours maybe if they were 2 strokes, and it would be fast too fast 70 plus , sick.
Old 07-15-2011, 02:21 AM
doodlebug doodlebug is offline
Come on dog, it does work, it's a classic Seacraft 23 not a classic bayliner 23. I know a man that had twin 250's on a 23 Sceptre fast and fun, it was tons of ajusting to get good all around preformance but yes it can be done. I miss my 250's until I drive past the gas pump.
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET
Old 07-15-2011, 08:54 AM
I remember that. Never got to go for a ride, though.
Fr. Frank says:
Currently without a SeaCraft
Old 07-15-2011, 05:52 PM
Been there done that with a 23SF with twin 225's. I would go single 250. I hit 59 on GPS with the Mercury 225's at about 5500 rpm. Balance is quite different with 1 vs. 2.
Old 07-16-2011, 12:55 AM
Dude - these are 4 strokes were talking about, not your badass Merc's. I am also kinda pissed I never got a ride either but never was convienent. They think they got me going again, found something in a fuel line - so I will be feeding it this weekend.
Old 07-14-2011, 08:08 PM
It's not too much power, some years of the 23' were, in fact, rated for 500 total OB horsepower. It is, however, too much weight.
Fr. Frank says:
Old 07-14-2011, 08:34 PM
bigjim2500 bigjim2500 is offline
I just sold twin 225 johnsons that were on my 23. It was a blast on flat water. If it got above 3' it would beat you up. The stern would fall off the wave no matter how much I was in the tabs. I needed to add weight forward. I run 20-30 miles out on a regular basis and if it picks up I have to crawl in. Plus all that weight back there would drag you off plane under 2800rpms.
Jim
1979 23cc
Twin 98 Johnson 225s
