Old 03-09-2012, 09:40 PM
gregorymacc gregorymacc is offline
Default non seacraft deck
I have a non mako project. I am replacing the forward deck on my 1993 27' Ocean Master. I have got most of the wet wood out. There was no rot in the deck. http://im1.shutterfly.com/media/47a2...D550/ry%3D400/. I cut the top skin off and plan on reusing and then painting the old nonskid wit kiwi grip. I have left about a 2" lip where the sides radius into the deck. I am going to grind this down then use 6oz tape to tab the deck in. http://im1.shutterfly.com/media/47a2...D550/ry%3D400/ Is there any tool or suggestion to get the remaining wood from the deck? I plan on using divinycell H-60 for the deck. I am using vinylester resin for this project. on a side note how do I post pictures?
Old 03-12-2012, 12:24 PM
fdheld34 fdheld34 is offline
here you go..just save pics to desktop and then go down to manage attachments/browse/upload
Old 03-12-2012, 05:25 PM
From mrobertson's thread in this forum:
Originally Posted by mrobertson View Post
...Here's a tip if you ever do a floor the way i'm doing this one. Go to harbor freight and spend $15 and pick up one of these :
I chiseled out the wood in the boat by hand the old fashioned way, with a hammer and chisel. I had enough of hitting myself in the hand with the hammer so after some research i came up with the air chisel. I still had to remove the wood from the top skins i cut up out of the boat and it worked like a dream. Quick and easy :
-Mike
Blue Heron Boat Works
Old 03-17-2012, 07:53 AM
Few more updates of the work I have been doing. The entire forward deck is up and out. and I have ground down the topside skin. I am going to recore with divinycell h-60 then lay the old glass back on top.
I plan on tabbing the deck back in with a couple layers of 6oz tape. I only have about a 2" lip to work with then the deck transitions to the inside radius up the sides.
