Old 12-18-2012, 09:02 PM
Default Fairing
I'm using polyester resin to glass the console I modified. I bought some poly fair from Mertons and was wondering how you guys fair. Heavy first coat, sand then as many thin coats as needed to get it right. Or many thin coats sanded in between each coat. Thanks for the help.
Elijah
Old 12-18-2012, 09:13 PM
Got it...much like traders fairing issue a while ago, it needs a thick coat to cure properly.
Old 12-19-2012, 09:42 AM
bigeasy1 bigeasy1 is offline
I've had great results with Polyfair,no matter how thick or thin when applied.I used it to fair out extensive damage to the gunnels that the previous owner did,and used it on the rear cap that I cut off when I did the transom.
Never had any curing problems with the Polyfair,no matter the thickness.
Mixed it up on a piece of flexible cutting board material,and applied it where needed,thick or thin.I had better results applying it in thin coats,rather than a thick coat that had to be sanded down.
It doesn't like to be under catalyzed,so it's better to work with small batches,and apply it quickly.
The flexible cutting board mats from the dollar store work nice,any remaining cured waste on it comes right off when you flex the mat.Re use it over and over.
All this,just for a boat ride
Old 12-19-2012, 09:49 AM
Now I find this out! After cutting up hundreds of cardboard boxes and the project nearing completion.
Good tip.
Old 12-19-2012, 01:26 PM
that is a good tip!! I will definetly pick some up today. I bought just a quart of poly fair the other day to test and it and i used the whole thing and it came out great. so i just ordered another gallon of it today. thanks for the tip and your history on the product.
Elijah
Old 12-19-2012, 04:00 PM
bbh57 bbh57 is offline
I use paper plates.
Old 12-20-2012, 09:37 AM
Elijah
Watch for ups today.It shipped last night.
Old 12-19-2012, 08:27 PM
BigLew BigLew is offline
..or had a "dust-up"! Your choice.
(couldn't resist- my bad)
Plan accordingly!
Old 12-20-2012, 09:26 PM
Mertons fiberglass in MA someplace. I think it can be used in colder temps but I'd check with Mertons though.
Old 12-21-2012, 09:35 AM
Mertons has it,I'm in there just about every night.He is in Springfield,(Western Mass).He ships worldwide and very quick,normally the same day if you order it in the am.
Not sure What you mean by cold temps,but It's a polyester based putty so cold temps will affect the cure.You can speed it up a little by increasing the catalyst,but it's best to keep the area at a comfortable temp.
You could apply it and keep some heat on the area by tarping in the area around it enough to capture some heat from a portable heat source.
