How often do you,guys reseal engine bracket bolts?
I,have water coming in. Half gallon an hour maybe? It's the only place that I,feel,it can be coming in. Not coming in from,bottom, fish box, or plug. It's About the only place I can,think of. Is this common? My splash well Is usually,closed off with,plugs in tubes so,it shouldn't come in There. .I may have a guy pick engine up and reaseal. And yes My transome is already wet. I've drilled holes.. and they Were wet..... Perhaps the water intrusion is from the bracket ? |
Check your brass scupper tubes if you have them. If the flare is gone on the bottom that could be the answer to your water issue.
