Old 08-07-2015, 08:15 AM
trave2 trave2 is offline
Default 1986 23 weight
1986 23
2006 yamaha F250
t-top
170 gallons of fuel
I will be taking it to the scale to weigh soon but would like to know what you think the weight is loaded?
Just need #'s
I already know the trailer is 900 lb with 750 lb tongue weight.
Old 08-07-2015, 08:59 AM
If we are taking guesses, I'll say 6000 lbs. BTW, you only have 150 pounds on the axles now?
Old 08-07-2015, 09:37 AM
That's a lot of tongue weight.
Old 08-07-2015, 09:43 AM
5,670# (Loaded boat and Trailer)
Old 08-07-2015, 09:51 AM
the tongue weight was just a quick idea on a truck I don't use with the trailer. The hitch probably would be set to high on the truck.
Old 08-07-2015, 09:53 AM
So about 6000 plus the 900 lb trailer would put me at 6900 to 7000 lb total. That would be on the high end right? Just trying to find a truck that would be able to pull it comfortably.
Old 08-07-2015, 12:03 PM
IMO, that's too high. My earlier post of est 5,670 lbs was the reasonably loaded boat AND trailer total.
A Ford F150 or Chevy 1500 (full size - 1/2 ton) pickup will do just fine. A Tahoe, Suburban, or Expedition are good choices too. I have pulled my 23' with all those mentioned -- no problems and mine is heavier than a 23' CC. Also, my trailer brakes (only on one axle) are kinda iffy too. A newer Tundra is more like a 3/4 Ton class pickup and will work even better although depending on load may be over kill.
I think we tend to over estimate the weights of these boats due to their quality build and our own bias.
The actual dry weight (without engine) of a 23' CC is only 2650 lbs. Sceptre is 2800 lbs
Old 08-07-2015, 11:27 AM
Tundra
Old 08-07-2015, 03:32 PM
Tundra
http://blogsdir.cms.rrcdn.com/37/fil...city-chart.jpg Interesting, about weight distributing hitches.
Old 08-11-2015, 09:39 PM
ocuyler ocuyler is offline
My 1989 23 CC is right at 5600 pounds with the boat, motor, fuel and trailer. Max. My ½ ton GMC tows her beautifully. Tongue weight should be 500-600 pounds.
Otto
