I've got a 1987 23 CC and the big fishbox under the casting deck has a molded in drain on the starboard side, but it's useless because it sits under the waterline. I don't use it as a fishbox, but occasionally i'll get some rainwater in there and there's no way to drain it.
Has anyone remedied this? Cut a drain to the bilge? |
That's what previous owner of our 23 did. He pretty much just drilled a hole in the recess of the factory drain so that any water makes its way to the bilge.
I had this problem. Found a 1-1/4" bronze overboard drain fitting, opened the hole then installed the drain. I was fortunate enough to still have a bit of the plywood backing in place such that I could tighten the nut on the fitting pretty well. Oh, I also shoved as much 5200 in there as I could. Had to buy a 1-1/2" expansion type drain plug and whittle it down to 1-1/4 with the bench grinder and took a metal shaping bit to grind the interior wall of the fitting smooth, since it was rough cast. Everything is holding well and the plug has not leaked any water in yet. I'll try to post a pic.
1975 SF18/ 2002 DF140 1972 15' MonArk/ 1972 Merc 50 http://i833.photobucket.com/albums/z...photos/SC3.jpg |
http://s833.photobucket.com/user/unc...tml?sort=3&o=6
http://s833.photobucket.com/user/unc...tml?sort=3&o=7
Can somebody tell me why I only get the link? ID10T problem?
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf |
