so this past weekend i primed my 23 DF with Awlgrip 545 epoxy primer. I must have got the quantity wrong from the coverage calc because 1 gal of base and 1 gal of spray converter barely got 2 coats on with a conventional sprayer with pressure pot 1.5mm tip. How much primer has it taken you guys that have sprayed 23's and will i need more than 1 gal of awlcraft/2qts converter?
Unless you’re set on spraying - I’d look into roll & tip. Paint goes much further and not as much taping. Finish comes out just as nice. Just my $.02. I used Awlgrip and it works fine.
The transfer efficiency (percentage of paint that gets on the part) for HVLP is 50-65%. Standard gun is ~40%. The rest is lost to fallout or drift.
Roll & tip is 100%. |
Interesting, I never realized so much was lost with a HVLP gun. No wonder the down draft booths do so well.
You should be reducing it too, lays it down nicer and you end up with more product. They say 10-25% but i typically go 33%, and even more if im spraying hi build. 2 gallons doesnt sound that far off if youre doing the bottom and hullsides?
it was not recommended to Roll/Tip 545 Primer and the recoat times were far too long to work for me. I have access to a paint booth during off hours but need to vacate before business operations so sometimes i only have long enough to spray after close of business, cure overnight (with accelerator), and vacate. I have some pinholes to fill anyway so i just bit the bullet, sanded, filled, and got 2 more gallons of primer base and 2 gallons of converter. i should have some leftovers for my console and leaning post but at least i wont run short...
also im using awlcraft 2000 for topcoat which is spray only.
So i decided to re shoot the primer with an HVLP gun with a 1.4mm tip this time and was able to lay down 3 full coats on the topsides (from chine up) all the way around including transom with 1 gallon of base and another gallon of converter then reduced 10%. I thought the pressure pot would have been easier because of the extra capacity but the HVLP was much easier for me to get a good even finish and was more efficient with material.
I rolled my Hull with 4 coats on one quart.. using 2:1:1 ratio of paint to brushing reducer to converter.. it becomes the consistency of water, smells like a potent winded, and you have the foam roller barely wet. Lays down like glass using the regular Awlgrip
