Old 06-28-2019, 12:46 PM
Default Color Match for SeaCraft Yellow
I am trying to find a paint for my transom with a reasonable match to the yellow gelcoat on my ‘76 Seafari. Don’t know what the yellow was called, darker than Fighting Lady Yellow more like Federal Yellow- but that’s not it. Signature Finishing in Stuart was unable to do it. Anyone been through this and have a paint and paint code. Thx
Old 07-12-2019, 01:00 PM
bobbert bobbert is offline
Default Yellow Finish
Give Awlgrip Lemon Yellow #h9265 a look. May be pretty close. Do you have a Awlfrip color chip chart to find match? Good luck. You could also check with a good body shop paint supplier, they can custom blend.They have a hUge number of chips for each color. When you find a match they can custom blend a two part poly paint.
Old 07-12-2019, 07:28 PM
Default Seacraft yellow
My cutout was too small for Awlgrip to match. Said they needed 2”x2”. So bought Awlgrip brightside yellow F9316 which looked closer than lemon yellow to me. It will only be on transom and has not been sprayed yet.
Thanks for response.
Old 07-13-2019, 10:33 AM
Sherwin Williams can color match with a 1/2 inch circle. Maybe ask them if they will print it out for a fee?
Old 07-13-2019, 02:37 PM
That's what mine looked like in "79
I was called "BANANA BOAT" on the CB Radio
Old 07-29-2019, 06:35 PM
As a yellow SeaCraft owner I know this is tough. I think the color Bigshrimpin recommended looks close from the picture. The original color definitely had some mustard color in it.
Capt Chuck - Awesome boat!
Old 07-13-2019, 08:11 AM
http://www.uscomposites.com/pigments.html
Terry - Take a look at the golden rod yellow pigment. I think it's close to the original seacraft yellow.
Old 08-08-2020, 07:31 AM
For anyone that is interested . . . I bought some of the golden rod yellow pigment from US Composites and it's far from a match. The golden rod yellow pigment is an almost identical color to the yellow lines in the middle of a street.
Old 08-08-2020, 03:58 PM
Default Color Close Enough for Now
Tried darkening awlcraft yellow with black pigment last April. Based on small samples thought it had turned out closer. For now it was time to get on with it, so used black tape as demarcation and cover the interface between original yellow and redone transom.
Old 08-08-2020, 04:04 PM
Default Here is the missing photo
Little trouble adding photo. First time directly from iphone without using laptop
