Old 11-05-2019, 06:25 PM
rcnight rcnight is offline
Default 20 SF Fishbox
Gents: On the 20 SF, in the forward fish box, particularly the drain area, does it rest right onto the inter hull? I'm speaking about the thru-hull drain. Thanks
Old 11-05-2019, 06:45 PM
mnwnvc mnwnvc is offline
My1968 did not. Was connected to thru hull with rubber tube. Not well done from factory. I cut a 6" access in the end of fish box next to drain to repair.
Old 11-06-2019, 08:01 AM
My 18 had a piece of plywood about 4" x 4" between the box and the hull with the drain fitting centered. I imagine they did all of them that way.
Old 11-06-2019, 11:36 AM
steel686 steel686 is offline
On my 18 there is Potter Putty against the hull and about a 1/2” gap if I remember correctly. When I bought it 27 years ago, I would get a lot of water in the bilge and found the flared copper thru-hull was loose. Even though it was above the water line, I removed it and the problem went away. I think the flex in the hull made it a weak spot. So I glassed it over and drained box to bilge. About to rework it during the rebuild.
Old 11-06-2019, 05:22 PM
Like mentioned, normally the flared threw hull is in a piece of wood between the two. May have potter putty between the two or around the wood block.
Old 11-11-2019, 09:28 AM
I do see a 4x4 plywood block up there as well. I don't use that space as a fishbox so draining to the bilge might not work for everyone. Think I will plumb a line back to where I can see it drain or plug it.
