Old 08-13-2020, 07:16 PM
vintage23 vintage23 is offline
Default 23 inboard diesel
Has anyone seen or had a 23’ center console inboard with a Volvo D6 engine? Wondering about fit in the console, shaft size, etc...
Thanks!
Old 08-13-2020, 09:09 PM
15 posts.
Old 08-16-2020, 10:16 PM
Thank you, such a helpful reply. This is a great forum, I’ve been a member for a long time, however there are many members that are.......
Old 08-16-2020, 10:39 PM
Ed Ed is offline
There is a 23' inboard in Perkins Cove, Maine with a D3 or D4 diesel. Rides like a dream.
There is a 27' on the Cape with a D6 connected via a jackshaft to an outdrive.
The D6 is a big motor and not sure a 23 could handle the weight. Maybe?
Old 08-17-2020, 07:59 PM
Concerned about the weight and size of a D6.
Old 09-11-2020, 04:02 PM
OSEAD23 OSEAD23 is offline
I Have a 23 inboard with the 240 Hp Yanmar 4lha-ste with a 1-1.25 zf transmission. That engine if you can find one is about the same size as a small block chevy and a little heavier but not dramatically. My boat will cruise at 23-25 knots and run 29 maybe 30 on the pins. run the same prop as i did with Gas crusader 16x16.
I had seen one with a cummins 6bta but it was really wedged in. the yanmar doesnt require any cutting but i did change i'm i'm up the engine mounts to allow better engine mounts that absorb more of the diesels vibrations at idle.
jim
Old 09-11-2020, 04:11 PM
heres how it looks in the engine bay
Old 09-11-2020, 09:54 PM
Cape Cod Marine and Albin 26's run D6's and Cummins 380 and 425's. I believe they are the same width and depth as a 23? Imagine they must have stringers and box set a bit wider?
Old 09-21-2020, 01:05 PM
Thanks for the info. Beautiful Boat! My Dad has a pair of those Yanmars in his blackfin and loves them! I'll keep you posted on my decision. Still a lot of fairing and sanding before paint and assembly!
Old 08-16-2020, 10:45 PM
Thanks for the reply, I’m thinking the same. I currently have a 454 with a 1.25” shaft 17 x 17 prop. Currently restoring the boat, thin look no about next power. A D6 came to me, not sure? I love the torque of the 7.4L. Diesel would be nice!
