Old 12-31-2003, 12:43 PM
Scott Scott is offline
Default Re: Need 1/4" pre-laid fiberglass sheet
Originally posted by abl1111:
As to gallsing it in: I want to use a panel that can be fully pull forward / removed, allowing me to gain access to behind the panel when I need to do electrical work on the gauges etc.
Thx for the idea though.
<font size="2" face="Verdana, Helvetica, sans-serif">Gotcha !!!
As for the panel ... I wouldn’t build it up with mat. That might take awhile..I would put core material in like aircell or balsa (I think you can get that stuff 1/4") even luan would work....Then on the molding board...a good layer of Gel coat first ...let it slightly tack up/kick ...layer of mat ... resin .... core material ... resin and mat to finish the back side…..
