  #41
Old 04-17-2007, 06:24 PM
cooperrf cooperrf is offline
Default Re: The Seavette is @ Wildfire Marine
*please* change that bilge hose you used. It's thin and not smooth-walled on the inside. Your two pumps will have reduced capacity if you keep it around. Warthog will show you the picture of his dog chewing it soon.
Old 04-17-2007, 07:21 PM
lost2a6 lost2a6 is offline
Nice, is that baby gonna have power steering?
Yes it has power steering and it makes it super easy to turn.
I don't like that bilge hose either, however I couldn't find any 1 1/8" smooth hose around.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 04-18-2007, 10:30 PM
warthog5 warthog5 is offline
Can I make a suggestion?
Get rid of this plastic hose RIGHT NOW! It's junk and should be Outlawed.
It also slows the flow of water with the ribs inside.
This is the only thing it's good for. [Dog Toy]
Old 04-19-2007, 07:30 AM
Ok, it's gone! I was able to take the rigid 1" hose and heat it with a heat gun and slip it on.
Steve B
Old 04-19-2007, 10:48 AM
WillyC WillyC is offline
For what its worth, I found some hose on ebay. I questioned the seller and he said that the inside was smooth. I think I will give this stuff a shot - not sure about the quality but I'm going to order some and check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...108079718&rd=1
Old 04-19-2007, 12:07 PM
I hate to say it, but a 1" hose probably isn't much better than the ribbed 1-1/8" you had before.
The stuff that Will posted is what you want and the price is right. I ended up getting mine from west marine. Even with a port supply card it was expensive: http://www.westmarine.com/webapp/wcs...001/146/145/11
Old 04-19-2007, 01:35 PM
Well I actually thought about that. It's going to have to work being as the engine is now in the boat and it would be a SOB to get to now. I wonder if the flex stuff is all that bad. It's been in the other boat for seven years now and still going strong, however it wasn't exposed to the sun or chafed with anything.
Steve B
Old 10-01-2007, 10:19 PM
Well I finally got around to getting some pics of the ole Seavette. This was Fri 9/28/07 at Horn Island. I'm still not finished redoing all of the teak.
Below are the custom speaker boxes that a friend made for me. I have a total of 8 6x9s in the cockpit and 2 12" Subs in the cabin.
Here you can see my amps. One is a 4 channel US amps for the 6x9s that is running at a 2 ohm load and is kicking out a total of 500 RMS watts, and the other is a Memphis Audio amp for my Sub which is also kicking out 500 RMS watts at a 1 ohm load.
Steve B
Old 10-01-2007, 10:39 PM
Steve-
Great job. She looks nice. Has to fly...............
Old 10-02-2007, 12:56 AM
Thanks for sharing the pics. That boat has go fast written all over it
