Old 10-31-2007, 09:13 PM
htillman htillman is offline
Default 23 Transom Replacement
I have removed the top cap and in the process of removing old transom. I have several basic questions:
1. What is the thickness of the plywood.
2. Approximately how much exposy will be required to install a new transom.
3. The boat is a Sceptre and I plan on having someone Awlgrip the boat - what type of cost should I expect and how many gallons of paint?
I will post some pictures in the very near future of this project.
Old 10-31-2007, 10:59 PM
lost2a6 lost2a6 is offline
Default Re: 23 Transom Replacement
My 82 Sceptre originally had a sheet of 3/4 @ a sheet of 5/8; I went back with a sheet of 3/4" @ a sheet of 1/2" marine fur. I made up the difference with glass. So being that I used a good bit of extra glass, I ended up using 15 gal of vinalester resin.
Steve B
1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH!
1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop
Old 11-01-2007, 04:05 AM
glow glow is offline
Wow Lost, I just wanted to confirm the amount of resin you used. 15 gallons? Thanks, Greg
Old 11-01-2007, 11:07 AM
bigeasy1 bigeasy1 is offline
My 74 23 Tsunami had a transom plywood thickness of 1-3/8".
I replaced it with two layers of 3/4"marine plywood glued together with epoxy resin thickened to a mayonaise consitency with cabosil.
The finished thickness now,including the inner and outer glass,is 2-1/8".
I used about 3/4 gal of epoxy to glue the plywood together.I'm using polyester for the rest of the project.which incuded the inner transom skin.
I don't remember how much polyester resin i used in the transom alone,but so far i'm up to 11 gallons,and i've done the transom, engine beds,(it's an i/o), recored two hatches, and recored a portion of the deck that was rotted.
I've also used about five gallons of hull and deck putty,that i get from Mertons Fiberglass.
It's a super polyester putty thats very strong,and is great for making a radius on sharp angles,where youre tabbing in,
bedding in cores, filling and fairing low spots,etc.
Not sure how much paint it will take to do a 23,but i think i'm pretty sure that i'll be using a two part urethane.
All this,just for a boat ride
Old 11-02-2007, 11:27 AM
EBEACH EBEACH is offline
I would guess about 5 gallons of polyester resin would be enough. It depends on how many paper weights you end up with.
Use a paint tray and roller to spread out the resin.
John, sounds like you are moving along with your project. Are you around this weekend? Please send a PM. I miss placed your number.
Thank, Jim
