  #121
Old 08-11-2008, 08:38 PM
Default Re: A New Boat to Check Out
Just when I thought it was safe to look at "repairs/mods" again....I see this, MR. and I do mean Mister Bonefish, outstanding may not be enough props for this project!! I'm giving serious thought to my transom re-build, something simple and then this masterpiece for ideas! Beautiful!
Old 08-19-2008, 03:29 PM
76Red18 76Red18 is offline
Love that dash lay out. Are those pull-switch knobs and labels custom items? What do you think your hard top weighs. It's foam cored so I wouldn't think it would be alot. I'd love to go that route at rebuild time.
J. M. Hendrix
Old 08-21-2008, 02:34 PM
Hammer Hammer is offline
I can't believe this boat!!!!
OUTSTANDING!!!
Old 08-23-2008, 10:47 PM
Bobv Bobv is offline
The switches are actually push buttons with separate LED indicator lights below. The labels above the switches are a single "rub down" transfer applied to the dash before the final coats of clear.
The hard top weighs about 50 lbs.
Old 08-24-2008, 12:03 PM
Considering the excellent and trick things you've done here, I beg your pardon for this question...
The instrument panel appears to be set on a hinging prism of sorts that closes flush to hide/protect everything when not in use. Is that right?
Old 08-24-2008, 09:17 PM
That's right. The top of the console is basically three pieces: the rear and forward sections are fixed, and the instrument panel is mounted to the underside of the middle section which rotates via a 12v linear actuator.
The instrument panel alone.
Old 08-25-2008, 04:09 AM
Bonefish, Like Guiness -- Brilliant! Can you show some more of that movement and the actuator layout? That is really cool!
Old 05-05-2009, 05:17 PM
nickalio nickalio is offline
F and B Boaworks in Savannah, Ga. http://fandbboatworks.com/
Old 07-04-2009, 04:30 PM
xxjwbuddaxx xxjwbuddaxx is offline
just wondering is this a 20 or 23 ?
thanks joe
Old 07-05-2009, 08:37 AM
thanks joe
If you click on the link above it takes you to the website...and it says it is a 23.
