Old 01-05-2009, 10:18 AM
1Step 1Step is offline
Default Awlgrip alternative?
Guys, I'm doing some minor gel coat repair on one of the chines and the boat is painted with Awgrip. From what I've read it's pretty tricky to apply and probably beyond my expertise. Any suggestions on alternatives?
It's not about quantity, it's about quality...and the experience.
Old 01-05-2009, 11:47 AM
Default Re: Awlgrip alternative?
You need to use a good high-build epoxy paint. Epoxy Mastic is excellent, designed for steel exposed to salt-water, and requires both sanding and a fiberglass primer.
Uraglow Gold is good, as is Interlux Perfection, both are topside paints.
Fr. Frank says:
Currently without a SeaCraft
Old 01-05-2009, 12:12 PM
joey joey is offline
AwlGrip is really not that hard to apply,however it is extreamly hard to color match once it has fully cured.Alexseal is my new favorite,much eaiser to match and not nearly as bad on your health.
Old 01-05-2009, 12:46 PM
Thanks Frank & Joey.
Will the paints you recommend be able to match the Awgrip color (cream)? This is the color when I bought the boat.
Can any of these be brushed on or should they be sprayed? Because it's on the bottom, I'm not as worried about it's appearance (although I would like it to look good).
Old 01-05-2009, 01:02 PM
all can be either brushed, rolled, or sprayed.
Fr. Frank says:
Old 01-05-2009, 10:07 PM
BigLew BigLew is offline
Please, please, please; be sure to use a respirator!
Awlgrip is a great product, but can be very toxic. It has been reported that a man painted his boat using Awlgrip, cleaned up and went in for dinner and died while sitting at the table! The fumes had destroyed his liver!=== Be sure to read all instructions and precautions!
Good luck, take care and be well.
Plan accordingly!
Old 01-06-2009, 09:50 AM
Lew, I'm leaning away from Awgrip but will use a respirator for whatever I decide on.
What do you guys think of Sterling paints?
