Old 11-12-2009, 08:14 PM
Ryan Ryan is offline
Default transom test
Whats a good way to check a transom for rot? The boat im looking at does not have a motor on it. Other than a rubber hammer, any ideas?
Old 11-12-2009, 09:26 PM
JohnB JohnB is offline
Default Re: transom test
The best way is a moisture meter.
The next best is a rubber hammer and drill some small holes in suspect areas.
Usually the problems are where the holes go through, motor mounting holes, transom screws, etc.
JohnB / 23' SeaCraft
Old 11-13-2009, 11:14 AM
Thanks, John im going to look for a moisture meter.
Old 11-13-2009, 03:48 PM
jerkinlips jerkinlips is offline
I could tell when i was tearing out the old wiring, each screw that I took out of the transom, water started seaping out. I good sign to me that the thing was wet.
Old 11-13-2009, 05:36 PM
Guest
Posts: n/a
In police work they call that a clue...
