Old 02-06-2010, 09:07 PM
Default Bunk question please.
My bunks were set up with about 1 1/2" "slop" total both sides just on the corner of the outermost step.
Go the same?
Cheers,
GFS
Old 02-07-2010, 09:38 AM
76Red18 76Red18 is offline
Default Re: Bunk question please.
Your steps are between the bunks right? I've got about the same "slop" at the rear of the bunks but tight to the steps at the front. Seems to load straighter that way. Also installed 6' 2 x 6 bunks in front for forward hull support. They are about 3" on each side of the keel. Got the idea from this site. First Load aluminum...Richard
Hey Sandy, check the timing on your motor. I thought mine was correct but it was 3 degrees retarded. Brought it up to 20 BTDC as specified and gained more mid power and 300 rpm.
J. M. Hendrix
Old 02-07-2010, 10:39 AM
Thanks Richard,
Engine test n tune is next.
Old 02-07-2010, 04:40 PM
I put mine on the middle V, just outside of the chine.
Fr. Frank says:
Currently without a SeaCraft
Old 02-07-2010, 07:18 PM
Dilligaf Dilligaf is offline
thats how mine are set up to
Old 02-07-2010, 08:02 PM
Thanks all!
Put em back where they were, on the inside of the outer step on the corner. Went thru a whole tube o TefGel.
53 " inside up front and 53 1/2" astern. All ss and Alum.
I decided to try color matching the gelcoat repair on the keel where the front V support had scraped off a previous 5200 job. First attempt was lemon yellow. Second was a little better, but I thickened like bondo w/ cabosil. I had forgotten how badly I do bodywork. There will be no photo documentation of this. I sanded it back down today. I did a small batch of straight Gelcoat and did a small repair on the chine. Got a pretty good color match.
Ole, 1 more weekend ok?
Cheers,
GFS
Old 02-08-2010, 02:24 PM
joema joema is offline
same as fr franks works for me
