Old 02-18-2010, 12:03 PM
datngrizz datngrizz is offline
Default Re: 79 MA restoration... here we go
may want o Re-tap the old stripped out hole and get the next larger set screw for a good temp fix
TNGRIZZ
Old 02-18-2010, 12:48 PM
Squido Squido is offline
Thanks guys I probably will tap and re thread them but if I can get a couple replacements then that wouldn't hurt.
Old 02-18-2010, 05:26 PM
CaptCurt CaptCurt is offline
The hull is completely gutted now. All wiring and traces of the liner have been removed, except the livewell and cooler areas in the back.
The front storage compartment/casting deck came out in one piece.
Scrubbed the coffin down and have it drying out.
I thought this was pretty cool.... underneath the Master Angler badge are the words "Master Angler" in pencil, written by whoever was assembling the console.
Here is the console, rigged as a Louisiana fishing skiff.... just add floats.
Working on my first project!
1979 20' Master Angler
Suzuki DT140
Old 02-18-2010, 07:02 PM
Tarpun Tarpun is offline
Same stringers as my '80 MA. How difficult was it to separate the liner from the hull? Dave
Tarpun
1972 20 Seafari
1977 23 Savage
1980 20'Master Angler
Old 02-18-2010, 10:29 PM
Not hard at all. When I jacked up the gas tank using my Patented Lift System , all the caulk joints popped. A good portion of them were already separated, so that helped too.
The hardest part of what I've done so far was cutting the coffin away from the rest of the floor liner. It is up against the stringers, so you can't go too deep or too far to the side. I put a few gouges in the stringers.
Suzuki DT140
Old 02-18-2010, 11:38 PM
Looking good. I was wondering what these boats looked like gutted and now I know. They are definatly deep at the bow. I think the front hatch in the step up could have the bottom cut out of it and lowered to the bottom of the actual hull to give you more room in it. I may do that when I start tearing into mine.
Old 02-19-2010, 07:17 PM
Dropped it off at Gulf Coast Composite today, they are going to do the floor and transom for me. I am not as handy with fiberglass as most of you guys, so I get to pay someone else to work on the old gal.
In the meantime, I am going to work on the console that et28 swapped with me. Gotta locate some electronics and gauges.
Suzuki DT140
Old 03-04-2010, 08:50 PM
Well, I was going to have Gulf Coast Composite do it.... but I found a guy working in his backyard that could save me close to $1000. Being the cheap bastard that I am, I went with it! Anyway, here is the new transom in place. I wish I had gotten some photos when he was putting the new wood in.
He got the boat off the trailer and onto his stands, so I am taking the opportunity to do an Extreme Trailer Makeover as well. This thing is a *piece*. Needs a new tongue, some patches on the frame, a new winch, repack the bearings, new tires, new wiring/lights, carpet on the bunks, and a few spray cans of Cold Galv.
Here is the boat on stands:
In the last picture, if you look toward the bottom of the hull, there is a drain which presumably was for the fish box. Does anyone see a problem with filling this in and just draining the fish box to the bilge?
Suzuki DT140
Old 03-05-2010, 12:20 AM
What may I ask are you saving by filling it in
Oh I get it: fish guts, blood, scales, salt water wash off, dirt etc running thru the bilge and then clogging up my pumps and creating a new Gucci scent within the confines
BTW: Great work & keep the pics coming........
Old 03-05-2010, 01:56 AM
Well, I'm not going to use it as a fishbox, just a dry storage compartment. I prefer an ice chest that I can lift out of the boat. It will most likely contain life vests, rope, and tackle boxes.
Suzuki DT140
