Old 04-18-2010, 10:17 AM
gman1001 gman1001 is offline
Default Sticker Residue...
Seems like a silly question, but here goes. Anyone have a good solution for removing the adhesive residue left over from the removal of old registration stickers...
Tx!
1988 18' Seacraft
1988 Mercury 115
Old 04-18-2010, 10:54 AM
CaptMick CaptMick is offline
Default Re: Sticker Residue...
I personally will use alcohol or thinner and then rinse it real well. Pour onto rag and wipe onto residue and scrub a little.
Old 04-18-2010, 11:08 AM
Xylene
Old 04-18-2010, 11:10 AM
the thinner or maybe try spraying the residue with wd-40 and letting it soak into the residue. then it should wipe off.
Old 04-18-2010, 11:18 AM
3-M Adhesive Remover
Old 04-18-2010, 01:18 PM
BigLew BigLew is offline
Acetone will almost always work. It is the active ingredient in nail polish remover. We used to use it at WM to remove all sorts of adhesive residue. Xylene(sp?) is nasty stuff and requires neoprene gloves, if you're smart! Also, there is Tyolene (paint brush dry paint remover) and is even more aggressive to your skin.
Just be careful and get plenty of ventilation and NO open flames!
Plan accordingly!
Old 04-18-2010, 02:59 PM
WD-40
See ya, Ken
Old 04-18-2010, 04:07 PM
WD-40
See ya, Ken
Yep. Fish oil in it does the trick.
Fr. Frank says:
Currently without a SeaCraft
Old 04-18-2010, 11:04 PM
3m general purpose adhesive cleaner is my prfeference, it's not hard on finishes at all but is very affective especially for older dried out vinyl emblems , stickers, glue because you can leave it on most surfaces without fear. I have also used it to remove many things it shouldn't be effective on but it seems to like to get under almost anything
Old 04-19-2010, 12:36 PM
I tried all of the above except Xylene to no avail. Go to an auto body jobber and get an eraser wheel. Magic. No more Slacker evidence...except for the driver.
Cheers,
GFS
