what type of floor should i use? Should i use marine ply or is there something else lighter? what is the cost difference?
I used marine ply redoing my 23 .one thought would be to make a pattern then use malmine board or I think strick uses mdm to make a mold .there is a plasic molding that plasterers use for around edges thats about 3/4 inch tall and has a bunch of holes on the othere side(90degree angle) you can screw it t the board cutting the on side to flex it where needed. I USED IT TO MAKE ALL MY HATCHES. wish I had made the floor that way it would hae saved a ton of $$$$ in sand paper and time.you can grind the edge where you would need to tie it together and glass sections together
Man deja vue.. I just otrdered 1 inch nidacor for my floor .. It is about the same in price as mrine ply but ther is not rot to nida core.. I plan on using this boat till i die.. Ther are more things to consider with nida cause you cannot just fasten anything to the laminate. You need to plan a bit more as to where your are goingt o afix parts to the deck...
![]() Quote:
nida core is made from recylcled milk jugs penske board,coosa,divinycell - these are a much better choice - stronger,more dense that nida core...much lighter,and rot resistant,unlike plywood...
do not let common sense get in your way |
i got ab for my transom, and was thinking it was a little heavy for the entire floor. is penske lighter?? i was recomended penske for the transom but could not find it up here. Have a friend who can get it in south fla tho.
I find penske 20 3/4 inch to be perfect for floors.
![]() Quote:
Display Modes | |
