Old 10-08-2013, 06:11 PM
Went with an Odessey group 34 battery AGM. Same size as my old one plus it has a full replacement warranty for 48 months. Less expensive than what I paid for the other one 2 years ago, and a better warranty.
Old 10-08-2013, 06:23 PM
Good call, Terry. I use Deka AGMs and they are on year 6, but you can't beat a 4 year replacement warranty. Who did you get them through?
Old 10-09-2013, 07:18 AM
My semi local "Batteries Plus"
Old 10-11-2013, 06:42 PM
sidelock sidelock is offline
You fried that battery with the battery tender. DO NOT use the tender on your new AGM batteries because you will fry them too. Get yourself a good quality proper charger to handle AGM's.
Old 10-11-2013, 08:06 PM
Terry,
I've had good luck with Deka wet batteries. Typically get at least 5 years out of them. Bought 'em from a local electrical shop I've been dealing with for about 30 years, were the owner is a real mechanic who will overhaul an alternator or starter instead of just swapping parts! Had good luck with an Optima AGM, but he quit carrying them because they didn't hold up. Switched back to a wet battery because it's not a good idea to mix types (charging requirements are different!). I used Sears Die Hard for a few years until I concluded it was just a battery rental program . . . none of them lasted more than 2 years but the warranty allowance was enough that it was slightly cheaper to buy another one than buy a REAL battery! Finally got tired of the hassle and bought a real battery! Denny
Another vote for deka here.
Old 10-11-2013, 08:53 PM
kerneltugboat kerneltugboat is offline
Another Vote for Deka AGM (Actually mine are West Marine SeaMate) or something like that. I was told by a friend that works for Deka that they were made for West Marine by Deka. She also told me that Deka gives West Marine a good deal because the owners of Deka love boating, etc and are tight with the West Marine guy's..
I bought mine in 2007, but really started using them in 2008 (Group 31 AGM). I can start my Diesel with either battery and they are still going strong. I am not looking forward to replacing them, I paid 150.00 each with my Port Supply card in 2007, now they are close to double that now. I do recommend a good on board charger that is Made for AGM, I think that is the main reason the batteries have lasted this long. Mine is a ProMariner Pro Sport. The first one lasted just over a year, then I sent it in and they replaced it with a newer, improved model at a small up charge. This one is going on 4 years. I plug it in the night before a trip.
It's not a Small-Craft, it's a Seacraft
Old 10-12-2013, 04:46 PM
I buy the Sears Platinum when they go on sale. The 31 size has the same specs as the Odessey, same size, case, ratings. Some say that they are not the same so I dunno, but I've had good luck with them. I wanted AGM because they are in the console and I was mainly concerned with shock loads. They charge up real fast which is nice also. I've also read, they like to be charged at 40 amps or more to make them last. My Yamaha F115 doesn't quite make that but so far so good. My Suzuki 225 EFI didn't make 40 amps either but when I sold the boat, both Sears Platinums were doing well after 2+ years.
Old 10-13-2013, 08:35 AM
Is this true
This is what there short description says:
The 2 Bank Battery Tender® Charging Station is two encased 1.25 amp battery chargers designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by trickle chargers. This charger will operate anywhere in the world!
2 independent charging stations.
12 volts @ 1.25 amps per station.
Extremely lightweight! Less than 3 lbs!
Operates anywhere in the world! 100-240 VAC 50/60 Hz.
25 ft leads available (NOT INCLUDED).
Microprocessor controlled constant current charging!
Reverse Polarity Protected.
Spark Proof.
Perfect for all AGM (absorbed glass mat), sealed maintenance free and flooded batteries
Complies with US and international safety standards (UL/CE).
2 year warranty!
Old 10-13-2013, 12:59 PM
ct9amr ct9amr is offline
I have had no issues with my battery tenders and agm's.
Glen
Old 10-14-2013, 09:12 PM
Who was the dealer terry or pm.
Call me crazy but i bout 4 batteries at west marine.
82 seacraft 20SF
Bayview Canvas
