Good call, Terry. I use Deka AGMs and they are on year 6, but you can't beat a 4 year replacement warranty. Who did you get them through?
![]() Quote:
You fried that battery with the battery tender. DO NOT use the tender on your new AGM batteries because you will fry them too. Get yourself a good quality proper charger to handle AGM's.
![]() Quote:
![]() This is what there short description says: The 2 Bank Battery Tender® Charging Station is two encased 1.25 amp battery chargers designed to fully charge a battery and maintain it at proper storage voltage without the damaging effects caused by trickle chargers. This charger will operate anywhere in the world! 2 independent charging stations. 12 volts @ 1.25 amps per station. Extremely lightweight! Less than 3 lbs! Operates anywhere in the world! 100-240 VAC 50/60 Hz. 25 ft leads available (NOT INCLUDED). Microprocessor controlled constant current charging! Reverse Polarity Protected. Spark Proof. Perfect for all AGM (absorbed glass mat), sealed maintenance free and flooded batteries Complies with US and international safety standards (UL/CE). 2 year warranty!
