Old 04-04-2014, 08:42 AM
Default Light weight filler
Can I use the 3M body filler (red/green in the tubes) to fill all the misc pinholes in the gelcoat? I sprayed some 545 yesterday and I see a few places I need to touch up but the pinholes are not deep and I have some light scratches also. I'm tired of sanding epoxy filler!!
Old 04-04-2014, 10:00 AM
This is what I use to fill pin holes over epoxy glass work:
Interlux watertight epoxy filler
http://www.jamestowndistributors.com...ct_ad&type=pla
It is thin enough that you can apply with a razor blade to little pin holes and it is smooth enough to spread well
Old 04-05-2014, 08:29 AM
Da Frizz is right!! Good stuff, easy to use and sand. Plus it's epoxy.
Old 04-05-2014, 02:44 PM
hermco hermco is offline
http://evercoat.com/productDetail.aspx?pID=29
Old 04-12-2014, 12:34 PM
If you have cabosil on hand, you can use it to thicken an ounce or so of activated 545 primer to a putty consistency. I've had good results with that mixture on pinholes after priming.
Blue Heron Boat Works
Old 04-16-2014, 10:13 PM
Blue heron I will give that a try. I have a gallon kit of the grey I need to use anyways. Just minor fairing to do. As of right now the Dolphin, Blackfin and Wahoo are in full swing. So my cosmetics are on the back burner!!
