can I steal the idea to use in my 20 MA... I plan to build a box to fit between my console and the step up..... this is bigger but scaled down with no curve... and the insulation is WAY above anything on the market !!!
80 23 SCEPTRE TWIN 135 MERC OPTIS 75 20 Master Angler 115 Mariner Tower of Power RUSTY PARKER http://i92.photobucket.com/albums/l2...eyemailtag.jpg |
http://www.boatbuildercentral.com/ ![]() my rebuild thread: http://www.classicseacraft.com/commu...ad.php?t=22090 |
Thanks for the coffin build and info on the boat build. Why did you go with a plank method vs foam core or cold mold (think you mentioned time and effort were a negative)?
Could you compare the 3 methods in terms of skill, cost, time, strength, weight? Thank you! |
http://www.classicseacraft.com/commu...608#post241608
more primer, more fairing. *PVC epoxied into the bottom for the mounting bolts.
![]() ![]() ![]() ![]() ![]() using the same hinges I used on the last coffin box, super heavy duty and rounded ![]() Using EMC highbuild primer, it sure fills and builds fast ! link to the primer: http://www.gulfstreamcomposites.com/...mers-s/126.htm
I prefer a sandwich hull, this one gets a lot of glass. Outside skin actually will have just about the same glass schedule if it were a foam core boat.
Another coat of EMC highbuild primer, then today the first two coats of Matterhorn White on the inside of the box. *Picture shows only the first coat. *Second coat gave full coverage. * The guide coat is just some spray paint, it lets you see where you need to sand and keeps you (hopefully) from sanding through. *Actually, I did sand through in some spots on the inside, but the paint covered just fine. *Paint is rolled on (no tipping) with a cigar style roller. *I used no reducer and it laid out like glass.
That's coming out awesome ...
sanded outside of box to 220 grit. *Used my neighbors spray booth just to keep dust off, rolled a couple coats of EMC Quantum paint on in the booth. *Used about 1/2 quart so far and covered about 56 square feet with two coats. * *I need to put a coat on the boattom of the box, and I may put another coat on the inside of the box, but besides that I think the painting is done. *The guy I am building this for wanted a non-skid pattern on the top, so that will happen next week after I install the hardware and gasket
![]() this picture was taken right after rolling the paint on, it is in the process of laying out. ![]() This is after about 1 hour, all tightened up and dry to the touch. * ![]()
