Old 01-22-2016, 10:12 AM
shine shine is offline
Moderator
Default Coffin box build
thought some of you might be interested in this. Building a coffin box using temp molds. Box top and bottom are cored with honeycomb. Made a mold for outside skin and a male mold for inside skin. Next step is to fill with foam...
Using all epoxy. Box gets faired before prime/paint. Painting it to match the boat its going on.
Old 01-22-2016, 11:53 AM
What is that new hull design in the background?....interesting.
Old 01-22-2016, 12:37 PM
Do tell....I have seen coffin boxes but you don't see to many plank framed hulls that have that much dead rise and that type of bottom contour, Almost looks like a plank framed seacraft on a slightly different scale minus the steps. Most of these are flat in the back much more. Looks like this one is modeled to have a more constant rise after the entry all the way back. Very nice on the coffin box indeed but love to here more the hull too. Is that douglas fir strips or juniper or something else?
Old 01-22-2016, 05:05 PM
SandlapperGT SandlapperGT is offline
Think this is the build Shine announced a few months back. 25 ft or so...Think he mentioned that lines were inspired by SC but no vdh (although that may be a future design).
Nice CB. What was your thought in making the one and outer skins filled with foam (2 part expanding?) Vs building out of a foam core or even seen roofing insulation.
Nice and thanks for the build
Old 01-23-2016, 02:27 PM
Moderator
The hull is a custom design for myself. 24 degree deeadrise, 25' (27 to end of brackt) Hull shape from chine down is similar to formula/seavee/whitewater/etc, but it has wider chines and a 6" keel pad. Shearline has a little dip towards the bow, but it similar to SC, and there is tumblehome at the transom. It unique, but of course the styling is inspired by some of my favorite lines.
Structurally, she is a composite sandwich hull. The strips/planks are a core, biaxial skins inside and out set in epoxy. Strips are mostly cedar, with fir on chines and keel.
The coffin box is coming along nicely, poured the foam yesterday, will pull all the molds apart Monday and start fairing.
Old 01-28-2016, 10:27 AM
Moderator
out of the molds and trimmed, next is fairing and making the bottom piece.
Old 01-28-2016, 10:50 AM
looks good! Nice job.
Old 01-28-2016, 04:50 PM
Cool boat, When I first saw it I thought "that looks like an seacraft crossed with an Ray Hunt rear section with chines added but with out the VDH". Sounds like you took the best of several good designs and made them work together. I bet that will be an light weight good riding hull when finished. I always wanted to do a smaller 25-28' plank frame Carolina boat with a more of an deeper vee instead of the traditional flat back. Something with the broken sheer line and tumblehome. I don't think the smaller hulls do as well as the bigger hulls with the flat low dead rise in the rear. 24 degress should help the ride on that length hull and hopefully the chines take the roll out. Sounds like a cool build. Post some pics of it as you work on it as well if you don't mind...
Old 01-30-2016, 10:17 AM
Moderator
Its going to be light compared to a glass hull of the same size.
My first drawings had a carolina style topsides with broken sheer and a little more tumblehome. More tumblehome decreased the cockpit width too much though. Form following function, what make a good traditional carolina hull, turns a "gimmicky" IMHO when you go to a 25 open boat. fine entry, flair, warped bottom ending in nearly flat deadrise is what makes a bigger carolina boat work.
It would be possible to modify this design to a VDH without too much trouble.
I have a ton of pictures, and I am keeping a build thread on other forums, just didnt think it was totally on topic for CSC forum, but I can post some pictures in an off topic thread.
Old 02-06-2016, 11:17 AM
Moderator
rolled some prime on yesterday, using the EMC high build epoxy primer.....
http://www.gulfstreamcomposites.com/...mers-s/126.htm
at least one more application of fairing, then several more coats of primer. *Will be cutting hole for drain and holes for mounting bolts next.
