Old 03-24-2016, 06:27 PM
shine shine is offline
Moderator
Originally Posted by jnamowitz View Post
Thanks Joel. I've got almost everything removed and I'm debating whether or not to remove the t-top or just tape it off really good. Also, before I prime, what grit should I sand the old gelcoat up to or does it matter? I use this international paint at work and it won't stick to a smooth surface. I need to prep the surface with no less than 120 grit or the paint will peel. If it's too smooth it's like it won't grab the surface.
Thanks in advance.
220 is plenty of "tooth", the paint will cover the scratches. Any more grit and you can see the swirls through the paint. If you have to sand the paint between coats, then sand the paint with 320
Old 03-24-2016, 09:52 PM
Perfect, exactly what I needed. I've decided to remove the t-top and every screw and bolt.
Old 03-27-2016, 09:56 PM
I still do t know how to add multiple picture from My phone. Stripped bare
Old 03-27-2016, 09:57 PM
Even more bare
Old 04-14-2016, 01:09 PM
Default Progress
It's coming together. All the holes have been filled and smoothed out and now it's primer time
Old 04-14-2016, 01:10 PM
Default More
Anybody able to tell me how to post multiple pics in one post?
Old 04-14-2016, 01:11 PM
More primer
Old 04-14-2016, 01:12 PM
Default Top coating the cap today
Still don't know how to post multiple pics
I upload to photobucket, copy/paste multiple into a post.
Default More topcoat
2nd coat
