Old 07-10-2017, 01:52 PM
mazz888 mazz888 is offline
Default Hermco bracket engine height
Hey guys just looking for some feedback I installed a bracket on my 23 last year and this was the first run. Engine looks low to me but I'm not sure. This was a loaded bot full 50 gal livewell and 4 people I usually fish with me and other person. I have one hole left to raise it up.
The pictures arnt great but maybe someone can give me an idea if I'm in the neighborhood or not.
Thanks
Jason
Old 07-10-2017, 06:50 PM
Too low to me. Bushwhacker had a good way to see the AV plate-black electrical tape on the top to see it right above the water.
Old 07-10-2017, 07:56 PM
See all the spray?
Way too low.
Old 07-10-2017, 08:50 PM
Thank you I had a feeling it was way to low. I hope the last hole gets me high enough I don't want to put a jack plate on it.
Old 07-10-2017, 09:48 PM
Do us all a favor and take pics on the trailer with an azz shot...
I just got through mounting a Hermco on Jr's 23 Sceptre with a new
25" Suzuki 300 HP !
We are dead nuts with the mounting after his sea trial.
One hole up on the bracket. 5.75 inches from the bottom
of the boat to the plate.....
Simple geometry.
Old 07-10-2017, 10:22 PM
Although my experience with a Hermco bracket is on a 20, I suspect you may need a jack plate! Check out post #4 in this old thread about motor height.
Old 07-11-2017, 04:44 AM
Are you running on plane in that pic or plowing? At Don's recommend mounting height with Yam 300 in the bottom hole I'm right on on my 23
Old 07-11-2017, 07:42 AM
This was taken on plane.
Bushwhacker any recommendation on a jack plate I would assume the least set back and greatest height adjustment.
Thanks again all. I plan on bumping it up to the last hole and seeing what it looks like then.
Any other tips would be great
Old 07-11-2017, 09:05 AM
If raising it a hole doesn't do it, then make sure you have a stern lifting 4 blade prop and a fin. (I wasn't sure if you had these already). Those you can do easily before a jack plate.
Old 07-11-2017, 09:44 AM
Thanks I have a fin but it wasn't installed at the time of this run I will put it on and see what she looks like, any good prop brands to look for? I am sure i can find something on here. I'm itching to get this dialed in our Bluefin bite is starting to finally get going here in NE. Just for fun here's a small Giant 83'' coming over the rail last season.
