Old 04-21-2019, 05:07 PM
Benzzino Benzzino is offline
Default Core thickness for hatches and deck on 1988 23CC
Does anyone know the core thickness on the hatches and the deck on a 1988 23 CC? I have one side of the aft deck soft that needs to be replaced, the live well hatch is bowed down, the small hatch over the fuel tank as well as the large hatch over the fuel tank and under the console. Also, if anyone has any experience with cutting the core out of the bottom of the hatches I would appreciate any advice.
Old 04-21-2019, 05:56 PM
Kraken Kraken is offline
Deck is 3/4 plywood. Use an oscillating metal blade to access the core.
Old 04-21-2019, 06:58 PM
KNZ911 KNZ911 is offline
Look deeper than just the hatches! I see a complete resto in your future.
Old 04-22-2019, 12:39 PM
mikeyk mikeyk is offline
While servicing my fuel sending unit I realized that the hatch, while not spongy, had experienced water intrusion probably due to unrepaired screw holes by previous owner(s). The hatch weighed over 80lbs!
I took a circular Skilsaw with a carbide blade and cut out the waterlogged plywood core, leaving a 2" wide frame. After letting it dry, I cut out and inserted a panel of 3/4" Airex foam, glassed both sides and gel-coated and non-skidded the deck side.
Old 04-22-2019, 08:34 PM
Thanks for the responses. So do you think I should use marine ply or Coosa board? For these hatches. I was planning on replacing the deck in a few years.
Old 04-23-2019, 08:28 AM
Oldboat Oldboat is offline
I put 2 ribs on my rear hatch were all my 250 lb friends will be standing bottom fishing for hours drinking beer
