Old 10-20-2020, 05:28 PM
JBASS02 JBASS02 is offline
Default Side vs Rear Scuppers
I've been planning to do side scuppers with rubber flaps however I'm starting to second guess that plan. Does anyone have plus and minuses regarding the topic. The disadvantage of transom scuppers is loss of bilge space and more work to route through bilge area.
I've raised my decks ~2" so I think I'll have plenty of height for side scuppers, however I've never been on a smaller boat with them and don't often see smaller boats with them.
The red ellipse is the approximate location of the scupper
Old 10-20-2020, 05:31 PM
These are the scupper covers I have.
Old 10-20-2020, 06:49 PM
I liked how "Kmoose" did his out the side. Very efficient. Search for his build.
Old 10-20-2020, 09:26 PM
take a potter take a potter is offline
Alright I'm stumped. I have searched for Kmoose's build that is referenced above but can't seem to find it. If I look at all posts by Kmoose it gives me 20 pages worth but doesn't go back as far as his build. Does anyone have a link or a clue how to find his build?
Thanks.
Old 10-21-2020, 06:11 AM
Kmoose side scuppers
http://www.classicseacraft.com/commu...ad.php?t=27757
Old 10-21-2020, 06:28 PM
Kmoose if you see this would you do side suppers again?
Old 10-23-2020, 11:09 AM
So no one has a strong preference one way or the other??
Old 10-23-2020, 03:27 PM
I like side.. IF theyre high enough above waterline
Old 10-23-2020, 04:19 PM
Kinda tricky to explain and I'm not sure if it's factory installed. On my 23 there is a "pocket" 3" x 3" about 1" below the deck where the water collects and then goes about 2" down through a 3/4" pvc 90 and then out he back. If I went out the side using the pocket as the lowest spot I would gain about 2" to maybe 3". I'd do like Ken, out the side with a clamshell to keep water out when running. With 3/4 to full fuel and the new heavier engine the pvc drain out the transom is now always below the water.
Old 10-24-2020, 02:00 PM
I have them on my Egret 189...just round thru holes...work great ...way above the water line...I have some large plugs in my emergency kit just in case I ever need them and doubt I will..if I were to do them on a seacraft...I’d copy what Dirt has done.
Strick
