Old 12-25-2021, 08:17 PM
Thomas Thomas is offline
Finished up cutting most of the tabbing to get at the remainder ply in the bottom of the boat. The keel stringer is shot- you can see where it has been screwed into over the years.
It seems like when they installed the I/O 2x6 motor mounts they layered the glass over the mounts, down the hull, over the keel and back up to the opposite mount. I found the glass on the sides of the mounts were delaminating with water in the bilge area- prying it and cutting it back it seems like it works its way forward in the boat. Does anyone have any insight to where this glass should stop? i don't want to pull too much up.
Old 12-28-2021, 05:14 PM
Keepin' at it. Took the old transducers off, they were mounted in a cup as part of the hull with a ton of putty. Keel stringer was completely shot, cool to see a part number handwritten on the side of it.
Old 12-28-2021, 06:26 PM
fishingproblem fishingproblem is offline
Going deep, doing it right. Good job!
Old 12-29-2021, 11:05 AM
Yea that that thing outa there...it's like the guts on a shrimp...nice work
Old 01-01-2022, 08:10 PM
Cheg Cheg is offline
Boy does this bring back memories. Mine was a 76. Used all composite for transom and floor and have no regrets. Took me four years though. Good luck.
Old 01-03-2022, 09:09 AM
Originally Posted by Thomas View Post
Thanks. My keel stringer is wood i removed a square from the top of it about 4' forward of the transom. Its wet stabbing a chisel into it you can see the moisture. Would you recommend the pvc keel stringer mod i have read about to replace this? I assume i need to beef up the layup on the keel when i am down in there.
The vents will be in the way of the new transom 3" thick is what i am aiming for. Any ideas on new ventilation places? I personally like the no vent look
Just wonder why you need that much thickness if your staying with the I/O ? I converted my 23cc I/O to a bracket and especially with the full bracket found absolutely no need for anything more then the 2” thickness . If you stay with the I/O I would think the vents would be a real advantage in keeping the complete hull ventilated as at rest there is a low section between the CC and the bow that holds water and I would assume fumes as well.
Old 02-20-2022, 07:57 AM
Wattaway, the boat will have a single 300 and a stoner bracket on it, the I/O is long gone.I am going to aim for 2 1/4" inches by laminating x3 3/4" sheets + glass.
Old 02-20-2022, 08:01 AM
Slow going been cold in the garage up here in RI. I managed to get the transom all sanded down with flap disks, finding some delamination in a few layers of the transom glass which came from the I/O opening that was cracked. More clean up to do, then time to gather materials for the transom.
Old 02-20-2022, 12:44 PM
More grinding today. The transom is cleaned up most of the keel stringer tabbing is gone- just need to grind the fillet flush. Pictures of the I/B cracking i have to grind back. More grinding to come
Old 02-21-2022, 03:27 AM
Looks familiar and you’ve got a good plan with 3-3/4” plys. Beyond a tyvek suit I’ve had good success putting lotion on skin before grinding seems to keep glass out.
Then I fold up some tape over my hand adhesive out and pat my skin down to pull the glass out works pretty good overall.
