Old 10-26-2003, 05:29 PM
el pescador el pescador is offline
Default boot stripe at waterline
is there a rule of thumb on where the boot stripe should fall at the waterline on every 20 ft seacraft are is it different for every boat and motor combination ...please inform me if possible......thanks
Old 10-26-2003, 05:46 PM
Mark Mark is offline
Default Re: boot stripe at waterline
there are many different fuel tank and engine configurations out there. Even if you get a definite answer, I'd still splash the individual boat to determine where it should go. I've heard of as little as 45 gallon tanks and as large as 105. Similarly, some people have Honda 130's on their boats and some have MUCH lighter engines.
good luck-
Old 10-27-2003, 02:29 PM
ScottM ScottM is offline
Dieter Sprockets
When my father bought our 23, the water line at the transom had to be lowered since the boat no longer had twins on it. We left it in the water a week or so and let a slight scum line build up to get an idea as to where to lower the line to. Capt. Brad's idea of a grease pencil is a good one.
Old 10-27-2003, 02:37 PM
Ed Ed is offline
Definitely strike the waterline with a grease pencil first.....nothing looks worse on a boat than waterline that is way too high.
Another hint for when you mask off the waterline. Affix the bitter end of the tape to either end of the boat....and then walk down the length of the boat while unrolling the tape. Once you're at the other end of the boat and have sufficient tape unrolled, cut/rip the tape, pull it taught, make sure the waterline is level and then rub the entire length onto the hull.The edge of the tape acts as a straight edge and assures a straight line)
Too many people make the mistake of unrolling & applying about 3 feet of masking tape at a time. Usually, it results in a waterline that is wavy and not level.
Good luck.
Ed
Old 10-27-2003, 11:48 PM
TUGBOAT TUGBOAT is offline
Here's Ya some SCUM Scott.I didn't know where to put My new swim platform ? When I got in, there was a nice Scum line across the stern ,Thankfully ,I was thinking, looked /remebered where it was before scrubbing it off ! I just hope its in the right spot !
Who sez We don't need SCUM !!
Scream'n Reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 10-28-2003, 01:43 AM
Good "?" Pescador ! I've wondered the same. I kinda like the clean look of it w/o. I also like the piercing look it gave before.Where would I mark it on the hull w/ the boat in the water ? "s above ? Take a grease pencil & make some marks?
TUG [img]images/icons/cool.gif[/img]
www.frenzie.com
