Old 05-02-2012, 10:55 PM
dandub20 dandub20 is offline
Default what type of floor matieral??
what type of floor should i use? Should i use marine ply or is there something else lighter? what is the cost difference?
Old 05-03-2012, 08:38 PM
I used marine ply redoing my 23 .one thought would be to make a pattern then use malmine board or I think strick uses mdm to make a mold .there is a plasic molding that plasterers use for around edges thats about 3/4 inch tall and has a bunch of holes on the othere side(90degree angle) you can screw it t the board cutting the on side to flex it where needed. I USED IT TO MAKE ALL MY HATCHES. wish I had made the floor that way it would hae saved a ton of $$$$ in sand paper and time.you can grind the edge where you would need to tie it together and glass sections together
Old 05-03-2012, 09:53 PM
martin martin is online now
Man deja vue.. I just otrdered 1 inch nidacor for my floor .. It is about the same in price as mrine ply but ther is not rot to nida core.. I plan on using this boat till i die.. Ther are more things to consider with nida cause you cannot just fasten anything to the laminate. You need to plan a bit more as to where your are goingt o afix parts to the deck...
Old 05-04-2012, 07:51 AM
pelican pelican is offline
nida core - like any other composite will not hold a screw - no composite has that ability
nida core is made from recylcled milk jugs
penske board,coosa,divinycell - these are a much better choice - stronger,more dense that nida core...much lighter,and rot resistant,unlike plywood...
Old 05-04-2012, 08:59 AM
i got ab for my transom, and was thinking it was a little heavy for the entire floor. is penske lighter?? i was recomended penske for the transom but could not find it up here. Have a friend who can get it in south fla tho.
Old 05-05-2012, 06:33 PM
bly bly is offline
Default Where are you that you can not find penske or coosa up here??
I find penske 20 3/4 inch to be perfect for floors.
Old 05-07-2012, 11:08 PM
I understnad but if you cor the miss where you are going to fasten harwares then it will work fine pclus a. Fraction of what corecell and penske goes.for
