Old 03-06-2003, 08:14 PM
barnacle barnacle is offline
Default Re: Props
Thats a hard question. YOu can run two of the same boats set up the same way and they will turn different prop sizes. The dealer should be able to prop the boat for you. Be sure to try a 4 blade prop. That will be the best to go with. THe problem is if your dealer does not offer finding the right prop you can spend alot of money trying different props. If its a good dealer they will offer this service.
