Old 08-29-2004, 11:44 AM
Default Bolting / Sinking screw into a nida-core panel
This page shows how to reinforce a nidacore panel so that it can take screws/bolts . . . basically says to fill the area that will be receiving bolts with a polyester or epoxy putty before you laminate the side. Looks promising!!
http://www.protechmarinecenter.com/n...e/Repairs.html
Old 08-29-2004, 03:01 PM
warthog5 warthog5 is offline
Default Re: Bolting / Sinking screw into a nida-core panel
Here's another webpage on that subject.
http://bertram31.com/proj/tips/sleeving.htm
I used both methods. In the transom I used PVC tubes where heave stuff will be mounted.
Where small pieces like wiring will go thru I filled it with epoxy putty.
