Then 13,500 sound pretty good, provided they run....That is actually a decent deal.
Trayder The engines run,The oil pumps are remove(mixing oil) is this a problem? The owner sent me some pictures today.The boat does not have that big splash guard.THANKS Keith
Having the oil pumps removed is not a problem, alot of people believe it is actually better. The only downside that I know of is having to mix oil with your large amount of gas.
20 SEACRAFT SF / 29 SEA VEE F.S.U. / REEL SWEET FISHING TEAMS |
I premixed on my old boat after I had an engine rebuild. Premix is fine, just two minor issues.
First, you have to put gas in the boat in even quantities (at a 50 to 1 ratio). Second, because you will have a straight 50 to 1 mix at all times, the engines may smoke a little when trolling (my old engine did anyway [buy, hey it was a JonnyRude, and JR''s are supposed to smoke). At the very least you should know the compression numbers.
