Old 04-23-2012, 12:00 AM
martin martin is offline
Today I started to remove the Transome core. Man what a mess. I made sure the transom was over the Trailer bunks before removing the core. I cut about 5-6 inches back from the transom across the stringers and removed the foam core . and then cut the perimeter around the transom. I then used block wedeges and pry bar to remove the plywood core.. The outer skin is very thin so I had to be careful not to damage it.. Like 0.125 thick. I never thought it was going to be that thin.. I did see about 0.0.25-0.375" thick of cabisil to bead the plywood. to the outer skin and then about 0.25 on the inside
