Old 07-26-2012, 06:17 PM
mperkins mperkins is offline
Default Thanks for a good paste-ing
Thanks for help I'm better boatman than a user of brains.
20’ Sea Craft Master Angler
1985 Hull
1995 150Hp Evinrude 502 hours
Improvements, starting at the bow.
Pop up nav. Light.
Snag-less SS fairleads for anchor and docking lines
“Starboard” anchor locker hatch
Spare prop mounted on underside if fish box deck
Bilge access hatch in bottom of fish box
Bronze thru hull in fish box, replacing plastic
Engine oil bottle mounted in catch pan
Off season vent hatch to vent fuel compartment
Twin battery hold downs
Master battery switch
Large access hatch in front of console
3/8” windshield
“Starboard” dash panel with tackle pocket and tackle hatch
Light switch in tackle pocket. Will light pocket and inside of console
Tach, temp and voltage gauges
Apelco VHF flush mounted ???
3’ antenna with removable mast. Stainless base.
Lowrance x 75 sounder ???
3 ˝” flush mount compass ???
Sea Star Pro hydraulic steering
Release Marine alloy steering wheel
Hour meter
Circuit Breakers
Fuel tank removed and coated with Interlux Barrier Coat
Bronze thru drain in fuel tank compartment
In tank fuel gauge replaced
Deck hatch to fuel gauge replaced
Bilge access hatch in splash well replaced
“Starboard” door for fuel filter access
One and one half inch bronze thru hulls – cockpit drains to overboard with backflow preventers
Keyless fuel filler cap
Wood trim replaced with plastic moldings
Cockpit sidewall fabric liner replaced with PVC panels
Full canvas winter cover
Fishing related
Schafer sixteen-foot outriggers (never used)
Cannon down riggers
Six rod holders on gunnels
One rod holder on top of console
One ninety-degree rod holder on casting deck
Two rod under gunwale rod storage, each side
Five-rod storage holder on console side with heavy wall tubes
These improvements were done in the late 90’s and some will need to be redone.
