Old 12-17-2012, 11:46 PM
Cheers,
Mr. Dumas,
GFS
Spidey must live.
mr sandman,
spidey otay, an meemaw an peepaw
merry christmas
an too all a good nite
Old 12-18-2012, 02:37 AM
Briguy Briguy is offline
I purchased Signature paint to do my top deck and verticle interior. Also will be used on my teak. Should be doing some test painting soon. I'll let you know. All the supplies and enough paint to do my entire interior and bilge cost about $300.00. They even matched my previous Alwgrip color.
Capt. Brian
Old 12-18-2012, 03:59 PM
Originally Posted by Briguy View Post
I purchased Signature paint to do my top deck and verticle interior. Also will be used on my teak. . .
Brian, as much as I like Signature paint, the Honey Teak treatment, which was the best product of it's type a few years ago, is no longer the best teak varnish. I've also used Epifanes Woodfinish Gloss, and found that it holds up better, no mixing is involved, and it also does not darken the wood as much. I varnished all my teak in 2006, with Honey Teak on the cabin door and Epifianes on all the rest. The cabin door finish is starting to deteriorate, but the rest of the teak still looks great. PowerBoat Reports also tested both and picked the Epifanes as the best. The key difference between the regular Epifanes Gloss varnish and the Woodfinish product is that the latter does not require sanding between coats if recoated within 72 hours, which makes it easier to quickly build up multiple coats.
I've also been doing some research lately on varnishing a mahogany front door for the house, and I've found the Epifanes, although expensive, is also the varnish preferred by most professional woodworking guys as the most durable for external use.
Old 12-18-2012, 09:36 AM
Nice hearing from you Spidey!!! Been a long time. Hope all is well! Merry Christmas!
Old 12-18-2012, 02:58 PM
Handful in NC Handful in NC is offline
I just finished (5 days ago) a full rehab on a '77 Sceptre on which the outer hull, top deck/inner cockpit/cockpit deck, and windshield frame were painted with Signature paint in Awlgrip colors - Marlin Blue, Oyster White, and Black respectively. Pictures will be posted when the weather is nice enough for photos and I get time.
Signature paint is a pretty impressive product. I followed the instructions for 3 coats using a simple cabinet roller, and the boat looks great. Not perfect. Not as good as a decent spray job. There's the slightest bit of "orange peel" look that you CAN eliminate with some additional sanding and finishing steps if you want to go to the trouble. But here's the thing and what most DIY guys want to know - I did all the prep and painting myself without fancy equipment and can honestly say I got 80% of the looks with 20% (or less) of the cost and labor. My '74 Tsunami was professionally spray painted, and most people would not be able to tell the difference between the finishes on the two boats. Consider that a strong endorsement.
Like with all paints, the prep is the most important part of the process. Any pre-paint flaws will show. Actually, the best thing about the paint is subsequent touch-ups are easy, fast, and undetectable. That was a major consideration for me.
I can't comment on long term durability, but if it looks good for a decent period of time and is dirt simple to repaint, who cares. On most boats, the finish is going to get banged up in a few years anyway.
The Signature with non-skid additiive looks great on the top deck, but did not hide flaws well. My cockpit deck had some dings and scratches that I did not want to fully repair because of the trouble or the need to preserve the factory stripes, so I used Kiwigrip. It's even easier to use (no fumes, water clean-up) and the aggressiveness of the texture can be greatly varied. Another very impressive product.
1974 23' Tsunami, fully refurbished, custom pilothouse, Hermco Bracket, 250 Etec
1977 23' Sceptre fully refurbished, soft top, I/O
Old 12-18-2012, 09:30 PM
Spidey has been outed No? Who was/is Spidey? Multiple personalities?
I have spiders in my bathroom. You should see our closets.
Snoopy is still funny,
GFS
Old 01-08-2013, 10:24 AM
Cheg Cheg is offline
Used Signature on hull and deck (non skid). Very happy with the results. Prep is easy but don't roll on if there is a breeze and your doing it outside. I have done it near the low temp. with good results. Haven't had to repair any nicks or scratches yet, but I have heard its easier than most. Most people think I sprayed it. I'm sure a professional would know though. Bushwacker, that was good and timely advice on the Honey Teak Finish. I am getting close to finishing a cedar strip kayak. Would have used it without reservation.
