Old 04-16-2014, 07:17 PM
alright I decided to re use the large front hatch and the bow hatch as my bilge hatch. They were close to size I wanted and they are already built. I know I will have to recore them but the hard work is done. So for my mold table I got some 3/4" MDF for the plugs. I added a 1/8" al the way around with a piece of luan. I then gave the radius of the corners with a steady hand and a pencil....
here I have the luan pushed up against the hatch to give myself 1/8"
After I cut everything to the size I needed I put a small radius around the top of it and fit them into place. Next came the radius wax that I got from Joe Merton (merton fiberglass). Basically I put it down in place and use a socket on an extenstion to radius around the plugs. I use a little heat to melt it into place.
I have the three plugs in place and waxed up. I have the layout of the stringers and the fuel fill also the rigging tubes. I am not gonna core a certain area under the console so I can make some cuts later and don't have to be so exact. the plugs you see are the bilge hatch, fuel sending unit/pick up and the front hatch
36' Yellowfin
1972 20' seacraft 140 suzuki
