Old 11-16-2016, 12:14 PM
Originally Posted by davids495 View Post
Thanks for the reply. I did think about raising the deck but decided against it as I wanted to use the inner skin. Now the core is down and I don't want to go backwards. Have I backed myself into a corner?
You can use Carl's answer to wet feet by closing off the existing thru hull floor drains and then putting in an elbow floor drain , then install PVC tubes crossing them out thru the transom with flapper type scuppers
ex: Port floor drain over to the starboard side scupper thru the transom & starboard floor drain over to the port side scupper thru the transom
