Bushwacker -
Great idea on the anchors for the bulkheads - I was kind of worried about the integrity of the old wood under the floor that the sheet metal screws bite into. I was planning to fill the old holes with epoxy, then drill new pilot holes, but that still relies on the wood. I like the anchor idea better. I may use that method in other spots too - like the door frame, where the holes are way oversized. I cannot read the sticker, as some prior owner glued a veneer of plywood over it, and when I took it apart, the glue took off a lot of the numbers. Is there a way to identify the null number or serial number any other source? |
If it hadnt been cut out by prior transom replacement, Hull ID would have been right below the cap on the upper starboard corner of the outside of transom. Check with glass guy to see if he took any pics of the area. Title would also have Hull ID if you have that.
Thanks, McGillicuddy: The transom did not have a hull ID number on it. the prior owner had to get an assigned number form Massachusetts at some point. Here is what the transom looked like before the redo.
John, I'd definitely save that picture in case you ever get boarded by USCG! Maybe even have that number engraved on the new sticker!
I ordered a new number plate in stainless steel from machineplatesonline.com that will get screwed to the hull in the same place. I will put a second identical plate inside the cabin, perhaps on the inside of the bulkhead inside the instrument panel cover. The prices for a 3 inch plate were not cheap - $60 for two. Cheaper than a ticket, though.
Found a 2002 Johnson 115hp 2 stroke at a nearby dealer. Price seemed reasonable (for Jersey) and I put a deposit on it. The dealer will hold it for a couple of months until I get the boat ready for it. The service history is good (dealer serviced) and it is one owner. Very Clean. Here is a couple of shots:
Great engine! I had a slightly older version on my Arima and I loved it.
Lots of grunt and decent fuel consumption. Never gave me any problems in 600 hours and required minimal maintenance. I miss that motor. Congrats! |
After one particularly rough Bahamas trip, I noticed the bottom screws coming loose, allowing the bottom of the bulkheads and door frame to shift aft, pinching the door at the bottom. I changed to machine screws & and threaded inserts on the bulkheads as previously described, and also ran a couple of wood screws thru the door frame into the sides of the bunks so they would be loaded in shear, and it's been solid ever since. Another option to threaded inserts for the bulkhead screws is toggle bolts. Although I've bought some from WM that had plastic zip ties running thru a plastic washer that help hold the toggle in place after you insert it, I'd still put a little epoxy on the toggles before installing them to insure they remain stuck to the back side of the fiberglass if you ever have to remove the screws. They're real handy for installing seat pedestals. (You typically have to drill about a 3/8" hole for a 1/4-20 toggle.) One other thing I'd do to the bulkheads before you install 'em is to saturate the edges and screw holes with some thin epoxy to waterproof them, especially along the bottom. Reason is that it's very hard to seal the bottom edge with caulk, so it's easy for wash down water to get under the edges of the bulkheads, and fresh water will rot 'em out even faster than salt water! Regarding the hull ID/SN, they didn't start using the hull ID numbers till 1973, so I doubt you'll find any numbers on the transom. I even had to explain that to a young USCG officer one time during an inspection who had never heard that! ![]()
[QUOTE=Bushwacker;249017]
Another option to threaded inserts for the bulkhead screws is toggle bolts. Although I've bought some from WM that had plastic zip ties running thru a plastic washer that help hold the toggle in place after you insert it, I'd still put a little epoxy on the toggles before installing them to insure they remain stuck to the back side of the fiberglass if you ever have to remove the screws. QUOTE] As always Bushwacker's advice is pretty sound. I would suggest doing a trial or two on a piece of scrap material if you attempting to use the WM toggle bolts with the plastic zip tie wings. I did and I was not satisfied enough with the results for an absolute solid anchor for my barefoot boom.- sorry, can't remember why. Maybe some epoxy as Bushwacker suggests to glue them might have helped. Thought they a little pricey too, but would have used them if I liked them. My '76 20' Seafari has the aluminized sticker under the helm like yours, but my bulkheads are fiberglass, so yours must be a little earlier model. |
Thanks, guys. I am not sure I want to rely on the plastic anchors of the toggle bolts, whether epoxied or not. Bushwacker: you used brass anchors? Where did you find those?
I am still deciding on whether to laminate a thin PVC or other skin to the outside of the bulkheads instead of using the plywood alone. I am definitely planning on coating all sides and bottoms in epoxy to prevent the problem of sweet (or salt) water wicking up the grain. As to the foil sticker, I will try to get the serial number from the sticker by rubbing, and see how it goes. |
