Old 06-09-2018, 07:26 AM
Originally Posted by fredbrad View Post
oh great!!!,I see good numbers and very good information,that measure of 29 1/2 "up from the keel, is in direct line to the bottom with a stick under the keel ?
eager to see those pictures,thank you for sharing so valuable information
It's with a stick pressed up to the keel running out past the bracket, then measured straight down to the stick.....to the center of the top mounting holes....to get the 29 1/2" number. In most cases the top mounting holes are 2' below the top of the bracket/transom. So...the mounting holes are actually 23" from the keel on a normal 25" SeaCraft transom. We added the 2" per 12" setback with the mounting holes not top of bracket.
