Porpoising if I use no trim tab at all. I don’t have a fine touch with trim so I’m sure I start with too much until on plane. Then I trim engine and tabs up for best speed. Don’t get me wrong, it’s more then manageable. I just can’t firewall-it without thinking like the old boat.
Gotcha, and that makes perfect sense.
Stood the engine up and mounted on a homemade stand the other day. Wired it and then fired it on the first turn of the key. After a small ground issue. Was VERY happy about that because I wasn't happy that I bought an engine from someone upstate without hearing it run, and let it sit for 2 weeks eating at my soul as to the soundness of my actions. But it sounds great and is soo quiet compared to my otherwise flawless 94' 150 looper (Shhhhh. I haven't told her yet that we are going to have to find her a new home), and I have the etec Tech guy coming today to put the computer on it and do a compression test. If anyone sees this in time, any suggestions about questions to ask or things to look for? There is one very peculiar thing though, the EMM has 200HO etched into it. I know the 200 EMM could be fine for the 175 because both are the 60 degree block, but he 200 HO is the 90 degree block..... (Shifty eyed emoji)
#24
If that eases your peace of mind any. ![]()
Zachary [SIGPIC][/SIGPIC] |
#25
That's an outstanding bit of info Erebus! Because even my mechanic that was on it today was a little stumped with that one. But I really can't thank you enough for that information. Overall everything seems good with the engine, few glitches, need to check water pump, although only 5 hours on the impeller apparently it's not functioning or efficiently enough. Hopefully it's just improperly seated seals. Missing Deutsch connector for oil tank connector. Missing plastic flywheel-EMM and injector covers/shrouds. Missing latches in Cowling for both sides, only front is intact. (Erebus, as you likely know the name association, my future 23 with the mercury 400hp is to be named "PBR Streetgang".)
#26
#27
Rybones, I you don't mind me asking, how much did you get the E-tec for? I am looking for a good used motor for my 20MA and used e-tecs are rare around here. Seems like nobody ever sells them...
#28
TFG, I was/have been looking pretty diligently for more than a year they are rare, I don't think you are going to find one for less than $5k and you have to act very quick. I have seen a few 175's and almost no 200's (25"). The 250's and 300's are far more common because of higher end repowers of twins. I have been looking for the 200 small block 60 degree because of the lighter weight as the 200HO is the larger block or 90 degrees and 100lbs heavier like the 225's and 250's. I still want a 200, but apparently I cant have one.
#29
If you have to change that filter in the vapor separator tank inlet, be very careful to minimize force on the nipple where it lives, because it’s easy to break off that plastic nipple! There is a little tang on the Oetiker clamps; if you cut it off with a Dremel tool, the clamps are easily removed. One other comment regarding the 135/150/175/200 hp 2.7L E-TEC power ratings. They are all basically the same powerhead, but BRP appears to be very conservative on the power ratings on the lower HP versions. NAEBM requires that true HP be within +10% of advertised rating, so true HP on the 135/150 is about 10% more than advertised, and maybe +5% on the 175 and maybe 0 to -5% on the 200! So bottom line is that the lower HP motors are surprisingly stong and if you’re looking for a used motor, they may be a much better “bang for the buck” than the 200! Your WOT speed with a 200 may only be 2- 5 mph more than you’d get with a 150 or 175! Intake and exhaust port location (analogous to cam timing on a 4-stroke) and exhaust tuning tweaks often used to get max hp on 2-strokes may also adversely affect mid-range torque, so engines with a lower hp rating may actually have MORE mid-range torque that you want for getting on plane with a heavy load or hanging on plane at lower speed in rough seas! My experience is that a strong mid-range power band is typically more useful and desirable than a few mph at WOT.
#30
All this. ![]()
