Thanks for the advice everyone. I'm thinking against it now but still want to see what the surveyor comes up with.
Keep your eyes open. Boats that have been redone fairly recently do come up for sale.
http://www.classicseacraft.com/commu...1&d=1594119183 A little snapshot of mine. Aside from the grumbling and moaning, I feel like everyone on this site who has redone one for their own use is extremely happy and confident in their boats.
My take is that the odds are strongly in favor of original transoms probably being compromised, at least to some extent. I'm not as "anti-wood" as some guys, if you start with marine ply and encapsulate in epoxy, but that's not how it was done in the 70's. And as the boats have aged, many have had holes drilled and not sealed correctly, not received the proper repair and maintenance needed, etc. So, yeah, I think it's probably a good idea to expect the transom to have issues - if it doesn't flex, doesn't have a reinforcing plate, taps solid, moisture meter readings look decent, and old screws and bolts come out dry, you're one lucky guy!
1977 23' Sceptre |
The surveyor checked it out the other day and you guys were right on. The moisture meter was pegged. I guess trying to find an original with a dry transom is like finding a unicorn.
Sad but not surprising.
It’s actually a very good exercise and quite an accomplishment when finished. Check your bulkheads too. Hopefully he did that? |
Just figure in the cost of the transom replacement in your negotiations.
I did my previous SeaFari 20' with ARJAY 6011 Ceramic Pourable Bonding Compound. I've also used it on two other boats. It was easy once I got the old wood out, and no cutting away the fiberglass skin on either side. But you do have to look out for nails or screws in the old plywood. Wear good safety gear.
