Old 07-06-2020, 12:43 AM
erock erock is offline
Default Should all Potter era transoms be replaced?
Hi everyone. I'm contemplating buying a '78 Sceptre (outboard version) with original transom reinforced with a stainless plate. I'm wary that there may be rot and have a surveyor looking at it next week. Seems like most people with Potter era boats redo their transom. Does anyone still run their boat with the original transom? And can they last 40+ years if well taken care of?
Old 07-06-2020, 07:20 AM
Why would anyone install a reinforcement plate if the transom is 100%?
Old 07-06-2020, 07:22 AM
"original transom reinforced with a stainless plate"
Hint....hint!! There's a reason the SS plate is there.
Old 07-06-2020, 09:58 AM
what they said...
Old 07-06-2020, 11:03 AM
rcnight rcnight is offline
While you’re in there, might as well look at the fuel tank.
Old 07-06-2020, 12:15 PM
My '77 has the original transom, and I know I'm on borrowed time. I removed a kicker a few years ago and the plywood was wet where it was bolted. The transom still seems very stiff with no noticeable flex...idk
Old 07-06-2020, 06:40 PM
Here’s a look at the wood in the transom from my 77’. Boat was in great shape, stored indoors most of its life and never in the water. Definitely check the tank in the process as stated above! DonV is spot on. Picture is upside down sorry.
Old 07-06-2020, 06:58 PM
Looks like my '78
Old 07-06-2020, 07:49 PM
Default My ‘76 transom condition
I finished my transom repair exactly a year ago on my 76 Seafari. The boat had been in the water for several years behind our house and the water damage was worse in the area of the engine bolts. All of my exploratory holes revealed moisture but they were portions of the transom that obviously were quite solid because of the difficulty that I had removing the wood with the forward and aft sheet still installed for a Seacast pour. I also found a few locations where the original plywood sheets were nailed together- Not too kind to the chain saw blade!
Old 07-06-2020, 08:03 PM
lelandtampa lelandtampa is offline
My 78 seemed solid trailering it home with a 115 Suzuki 4 stroke on it but after I took the aluminum trim off the top.. the mulch and ants that were visible told me all I needed to know.
