Old 05-24-2003, 11:25 AM
CMBarnes CMBarnes is offline
Default Re: SS Fuel/Water Separator .... which one?
I have been using them for years. I don't see why anyone one would use any other system. As stated above you can clean out crud and water while running. I know it has helped me on several occasions. I think it is a must on any outboard.
CMB
Old 05-24-2003, 04:13 PM
barnacle barnacle is offline
Go with the racor. Its a far better filter then the others. If your mounting it out of the bilge area of a inboard or io be sure to go with the plastic bowl vrs the metal bowel. The plastic bowl allows you to see what is in the bottom of the filter.
Old 05-29-2003, 06:15 PM
Thanks for the replies!
The SS Racor is ordered.
- Nick
Old 06-10-2003, 04:58 PM
The SS Racor is installed. This is a serious chunk of metal!
I needed to relocate to allow for the increased size. I bolted the new Racor unit to a piece of ply and then bolted the ply to the reused old bolt holes.
Looking good. I see a few fish in the bowl, but no water!
- Nick
