Old 09-22-2018, 06:36 PM
Default 1980"s era 20sf's
I should know this but just wanted to check with the pro's...I think I remember hearing that the later 80"s 20sf's are slightly longer then the earlier Potter era models? I see on the net where some are calling them a 21 rather then a 20. Also I remember something about a hook in the hull...I think that was on a 23 mold. Any thing in particular to watch out for if one was to re do a later 80's 20sf? Sandy I know you have one...
Old 09-22-2018, 06:52 PM
Hook was on the port side Sceptre 23'. After CSY around 1983 as I remember. I don't recall the 20' had changed in length ?
Old 09-22-2018, 07:30 PM
Default Sceptre Hook
If you search Bushwacker had some posts describing the hook. Don’t think it was on very many.
Old 09-22-2018, 09:17 PM
Doc, a 20 is a 20.
Nice to have you back.
Do you want my 20?
Old 09-22-2018, 09:24 PM
FLexpat FLexpat is offline
GFS will know for sure but I think you are right. My recollection is that the Tracker era(?) 20s were about 6" longer and had a slightly higher deck. The only hook I know of was on the 23 as Capt Chuck mentioned. I remember hearing about a slightly shortened 23 being sold as a 21 but that may not be accurate or it could have been a one-off; the beam would be the giveaway on that.
Old 09-22-2018, 09:45 PM
Joe R Joe R is offline
I have loads of old brochures at my office , but they made a 20 that was a bit bigger than the potter 20...but not a tracker...and they also at one time advertised the MA as over 20. If I remember I look over the brochures later
Joe R
21 SeaCraft 1998
Susie 2
Joe R
Old 09-22-2018, 10:00 PM
The 80's were 20 4" and the 70's were 19 6"
Old 09-25-2018, 07:42 AM
I second this^ the 80's model hulls were a tad longer, not sure where? but they did end up stretched out just a tad.
Old 09-25-2018, 08:28 AM
Bingo....
Current 2000’s 21 is a cut down 23SF. Over half of the references to a SC 21 currently come from someone rounding the length over 20 on a 20SF to 21.
Old 09-25-2018, 09:03 AM
Bingo....
The norm has always been to round up so a 19'6" gets to be a 20 footer and a 20'4" gets to be a 21 although I dont know if any of the 80's boats were marketed as a 21?
Now for another question since you've brought up the newer 21...I've talked to several people about the newer 21's being a cut down version of the 23. Yes you can see thats it's way bigger then the 20sf. The question I had was...how was the mold made on the 21? did they simply cut 2 feet off the back of a 23 and make a new mold from that? or has the gunnel height been taken down a bit as well. Anyone ever get a picture of the newer 21 and the 23 side by side? I realize that the interior was changed significantly and would rather not get into that.
