I have a 82 also with a bracket and full transom. Since a put the bracket on it sits even more bow down. It rides great. I have a 2001 225 fitch with a armstrong bracket. I have always put my motor as high as possible to lessen drag and get max rpms. Send me e mail address and i will send photo.
mad max |
I have an '82 also and it sits bow down, although we easily fixed most of the problem this past season by moving some things out of the cabin and into the bilge area (removed the in-deck livewell and created a storage area). My boat was originally rigged with twin 200's and carries 144 gallons of fuel. Now that it's got a single 225 Yamaha, it sits lower in the bow.
By the looks of the pictures, at rest it doesn't sit too low in front. |
I know a dealer who had SeaCraft from mid 70's
into early 80's and this was a real problem on the early CSY hulls. Water would collect in the bow area and had to install bilge pumps there. [img]images/icons/shocked.gif[/img] |
Glass in 150-200 lbs of lead weight in the stern. It's very small for it's weight. I have 200 lbs in (1) plastic milk carton. I bought 250 lbs of lead from a metal scrap place years ago for $75 ( to weigh the trunk of a BMW down in the snow ).
Car's gone. Now I have a life long supply of lead for sinkers for the melting pot ( make that 10 life times worth ! ) If I were in your predicament, and it bothered me, I would figure out a way to properly glass in lead. It won't rust. And if thought-out well and done properly - you could remove it any time... |
Thanks guys for all of the replies.
Madmax: That is interesting that your boat sits even more bow heavy with the bracket, Your bracket must be buent. If I was going to do this then I guess that I would need to pick a bracket that has absolutely no buency. My e-mail is lost2a6@cableone.net abl1111:I have thought of adding weight. I tried doing this when I re did the transom. I went with less wood and more glass. I ended up using almost 15 gal. of resin. This helped some with the addition of the jack plate. It wouldn't take much weight, I can sit on the engine and the water will run out good. I weigh 170 lbs. I just hate to add weight to an already heavy ass under powered boat. In a way I hate the idea of twins because of double the maintance and the fear of burning more fuel. I get 2.3 MPG right now at 30 MPH. (4200-4300 RPM) I think what the problem is the front deck is soo heavy with it's ¾” plywood and 3/8” glass on top and bottom of the wood. Again thanks for all of the replys, I really wanted to make sure that I didn't have water trapped some where.
Steve B 1978 23ft SeaCraft Seavette 502HP ZZ502 Mercruiser TRS Drive-Sold-UGH! 1998 28ft Carolina Classic 7.4 Volvo Penta Duo Prop |
This is kind of a "redneck" fix for your problem.. but you hate when you wash the boat down and the water runs forward.. . and if you sit on the motor it runs out and your 170 pounds.... Well 170lbs is 85 quarts..I had a boat with the same problem and what I did was to fill my 96 quart bait cooler with water after I washed the boat down.. added some soap and bleach and let it sit till I use the boat again. I put a 18" piece of hose over the drain and moved the plug to the end of the hose. When I used the boat I just pulled the plug and it drained out the scupper and I had a nice clean and good smell'in cooler and a boat that sat nice..
[ December 18, 2003, 07:00 AM: Message edited by: PipeDreamsMarine ]
Don Battin Pipe Dreams Marine "Design her right, Build’er well Bend the throttles, And let’er eat…." Carl Moesly |
![]() Quote:
