Old 11-22-2002, 10:54 AM
Matt1121 Matt1121 is offline
Default Re: moisture meter
Save your money. Moisture meters can and do give false readings....If you were operating it in a sealed environment they would be more accurate but since that is normally not possible things such as a puddle on the ground nearby, dew on the grass or high humidity can throw off the readings.
