Old 07-07-2002, 06:41 PM
white hawk white hawk is offline
Default Re: Thru hull scuppers ... How did ya fix em
John B, thru hull penetrations can be done easily if you use a hole saw with an extra long pilot drill. Drill your pilot hole completely through transom at the thru hull location. With hole saw larger than thru hull (say for example 1-1/2" for a 1/4" hole)Drill from inside removing material up to exterior skin. Now you have a small hole outside and a big hole inside. Fill the inside hole with thickened fiberglass putty(add some glass fiber if you want)and seal with plastic wrap and pressure bandage(ply scrap)You can drywall screw the bandage to the transom temporarily. When cured, put FG patch on inside over puttied section, when that's cured you can drill your thru-hull through this plug. You now have a FG plug that will not allow water to migrate to wood.I have used this method for thu-hulls up to 4" in diameter (inboard exhaust) with no leaks and no water migration to wood. It works.
Old 03-02-2003, 10:41 PM
EBEACH EBEACH is offline
Scott, did you finish your scupper work? If so, how did it all work out? I've got plastic ones, and I have a feeling I'll be messing with them once I have the liner out for the transom work.
Thanks, Jim
Old 03-02-2003, 11:52 PM
SECF3114M73J SECF3114M73J is offline
I've replaced my scuppers twice.A freind of mine who also owns a 23 ft'er is a plumber.He has a flaring tool made out of threaded rod, the piece that does the flaring is bell shaped. The tricky thing is that the hull where the bottom of the scupper is,is like a wedge, so the tube is not squarely seated. For brass tubes we used toilet stand pipes.The pipes come in 2 diameters, the bigger size is the one to use,don't remember but I think they are 3/4" dia. Be careful not to cut the tubes to long,if you do they will split when you flare them.
[ March 02, 2003, 10:55 PM: Message edited by: SECF3114M73J ]
Old 03-02-2003, 11:58 PM
Scott Scott is offline
Hi Jim
Well I have the tube from whaler and at the moment, in an attempt to get this thing in the water ASAP, I'm just replacing the scuppers as is (my original ones were brass.....) I still want to go out the hull sides or transom (instead of through the deck and bottom of the boat) but not until I know what I'm doing with the transom .... In other words .... No scupper changes this year
Old 03-05-2003, 11:10 PM
I knocked my through hull reverse clamshell rigs out of the scuppers in mine yesterday. The 5200 actually broke loose with not a whole lot of effort. The forward one in the fishboxI knocked out as well. Found that the hull was 3/4" thick and the circumfrence around where the fitting was was resined around it. Trying to find a local whaler dealer now to buy new tubes.
Old 03-06-2003, 12:09 AM
Standing Room Only Standing Room Only is offline
For mine, I used an oversized holesaw after clearing out the old. I used thinned epoxy in the hole to seal the edges. I then had patches of biaxial glass I soaked in epoxy, then placed them in the hole, tight with each preceding patch. You can build this up pretty quickly as the patches are doubled and it is not "too" expensive. After drying then used a 1/2" hole saw and cut out the center. Painted the inside with epoxy mixed with barrier cote. No more brass, and no chance of water intrusion to the new stern. Definetly overkill, but after redoing the transom -- didn't seem like too much.
Old 04-08-2003, 08:11 PM
Back again, I am thinking instead of brass tubes,etc i am going to do what standing room only describes only using West system and going straight thru the bottom of the hull. Here's how I think it can be done. Drill out an oversized hole thru around the present thru hull. Using duck tape on the bottom, also on the inside of the boat. Put a small hole in the duck tape on the inside injecting west system until the hole thru hull is full. (using plenty of the thickening fluff stuff)After curing for a few days , drilling out a hole the same size as the original so the expandable plug will still work. The whole diameter of the hole will be west system in with a nice border. What does everyone think or am I thinking foolishly here and should i just go with the brass tubes again ??? I plan on doing this the upcoming weekend (4/12-13). Thoughts, pros ,cons??? thanx-craig
(she's almost ready to go back in the drink,)
